135 ready to go into shop
dacaseguy
Got the loader off and pressure washed the 135 Perkins engine. I am going to roll it into shop today and hopefully get the head pulled. Then I need to drop the pan. I know it must have worn or broken rings. Dick
You going to put a new water pump on while you have it apart (easier to do it now). Seems like after you take one apart, and put it back together if you don't put a new water pump on, the pump will start leaking soon after its all back together.
Thanks for all the advise. I want to do it right but I'm not keeping this one. Bought it to resale. Should be a good little loader tractor once. It is up and running. Good brakes , power steering and fair rubber. Pulling the head today maybe the pan if I get that far? Dick
