Ok, still working on replacing the clutch on my TO35. I need to replace a seal between the pto and main shaft as that is where it is leaking. The manual is not clear to me. If just pulling this main transmission drive gear, can I just unbolt the four bolts and pull it out? The manual talks about pulling the main drive gear and the front pto housing bearing and makes it seam like a lot more work, but I only need to replace the seals on the main drive gear. If some one could help me out today that would be great as I am ready to tear into it.
Also, I have not been able to find the specs on the flywheel for this TO35 with dual clutch. I took it to NAPA to clean it up but they won't turn it without the specs. My local Massey dealer hasn't been able to come up with them. I need the width from the crank face and surface, then from the surface to the clutch cover mounting points. Any help would be greatly appreciated. Thanks, Bud
