Massey TO35 flywheel spec's
hrbburn
I am putting a new clutch in my TO35 and was going to have the flywheel resurfaced but NAPA wants to know the spec's. Mainly from the crankshaft mounting side to the surface, then from the surface to the top of the fingers where the pressure plate cover mounts. Can anyone help me out, as my local Massey dealer so far hasn't been able to get the spec's. Ready to put the tractor back together but need the flywheel done. Thanks in advance for any of your help.
Bud
They should be able to measure the step, surface the face and the step to match. Not saying yours doesn't need it but I've never seen the flywheels on any smaller MF tractor that needed resurfaced. Larger diesels, yes as they usually have more aggressive clutch discs that wear both the pressure plate and flywheel.
