MF35 Transmission
FoMoCo1
New User
Hi fellows! I have a 1960 MF35 Deluxe 6 speed dual stage clutch transmission with the Continental gas engine . I've recently had a bearing come apart and in the process chip two meshing gears. I desperately need a diagram for this transmission to figure out what this particular bearing and gears are and what these two different shafts are. I have searched for 3 days to no avail and came here for any help. I can post pics if needed. Thank you!
(quoted from post at 22:05:00 11/07/16) Hello
I have a transmission if you should need one.
Thank you Lance
I'd like to discuss that but the "private messaging" seems to be disabled on this site. Thanks Lance, Phillip
(quoted from post at 19:38:53 11/07/16) Hi fellows! I have a 1960 MF35 Deluxe 6 speed dual stage clutch transmission with the Continental gas engine . I've recently had a bearing come apart and in the process chip two meshing gears. I desperately need a diagram for this transmission to figure out what this particular bearing and gears are and what these two different shafts are. I have searched for 3 days to no avail and came here for any help. I can post pics if needed. Thank you!
I've posted these pics showing the problem gears and bearing location. The AGCO IPL is what I've been looking for!!!
1.These two lowest gears (lower counter-shaft?)mesh together of course. I believe the one on the right is the PTO drive but I'm not sure what the left side gear is.
2.The first web that the main-shaft (top shaft) goes through is where the bearing came apart.
3.The main-shaft front housing there is the oil or ball bearing retainer that has been torn as pictured.
Thank you Lance
Lance, I'd like to discuss you're transmission. If you would, use my post email button and shoot me a message.
Thanks, Phillip
