DavidP, South Wales
Good morning everyone,
Our recently acquired 3060 is throwing its first wobbly. Left home on Sunday to go on a charity roadrun only to find
that it was stuck in the 'Tortoise' range with no light showing. Research indicates that the problem can be
something as simple as a bad connection in a block connector. Certainly hoping that it is not a ECU problem. Working
my way through the block connectors as found and following the wiring diagram from the MF manual. All fuses checked
and OK but I'm having thoughts about a faulty key switch preventing power from getting to the Hare/Tortoise circuit.
Anyone had a similar problem with a 3000 or 3100 series?
Your thoughts would be much appreciated.
Thanks in advance
DavidP, South Wales
Thanks in advance
DavidP, South Wales
