150 exhaust
notebook
Got a big problem with my 150 with a diesel motor, it has a home made exhaust coming off the manifold and is falling apart I am trying to return it to the under slung exhaust but after talking with the local MF dealer the parts are not available anymore and they have no after market parts. I looked online and was unable to find anything the part # they gave me was 520241M91 and the muffler is 534523M92 I would even make it a vertical exhaust too if I could find the parts at a good price by the way it has an alternator any help would be greatly appreciated.
I find it interesting that the ones with a alternator uses a different exhaust manifold than the ones with a generator. With either the alternator, or generator they are mounted on the opposite side of the engine/exhaust manifold (so I don't see any reason why they need to be different) but they are. Anyways, if the flange that bolts the exhaust pipe to the exhaust manifold is still good a muffler shop can bend you a piece of pipe, and weld it to the flange. The parts available these days are kind of generic (one fits many others) so you want to call, and ask about these http://www.yesterdaystractors.com/c...amp;md=150&cat=Exhaust System&r=mcats
If you want to vertical you need elbow part number 519748M1, and muffler, and muffler 522589M91. You are probably going to have to call some places as most don't list every part they carry online.
Call around to your local muffler shops too. They have the machines to create just about anything you need. I used to run a muffler shop when i was younger and we did all kinds of custom stuff.
Did you look at the online shop here on YT? It looks like they have everything you need, as long as you are in the states or close enough in Canada to pick up a package delivered in the US.
I looked on the web site and have looked on other site but they don't seem to have the part that comes off the manifold and goes down. I talked to a local muffler shop and he said to bring the tractor there and he might be able to build one the only part that he was not sure about was connecting to the manifold. I haven't given up yet but is there a newer part number that I can use to get that part. The one that is on the tractor has been welded to the manifold but it will be easy to take off and grid back to the cast iron. Thanks
