Sealer on Power Steering pump gasket ???
Caryc
I had to remove my pump to replace the O ring between the reservoir and the pump body. Had a leak there.
Anyway when I removed the pump there was some kind of sealer on the gasket. It was red and still soft kind of like rubber.
Anybody know what this sealer was and do I need sealer on that gasket? It's a MF202 Workbull.
Sounds like some hi temp red rtv silicone, you usually don't need to use any type of sealer on a gasket unless the surfaces aren't nice, and smooth. Most people put a little sealer on the gasket to hold it in place, usually on the part that is removable.
