Need instant reverse thrust washers 1886555m1 and 1886553m1
gjinc
HI
Working on a 40B backhoe that will not move. I found that the pump is not pumping and the hub driving the pump all scratched up.
When I replaced the hub I noticed that 3 thrust washers are pretty scratched up also. debating on weather i need to replace these.
I need 2 of the 1 886 555 M1 and 1 of the 1 886 553 M1 thrust washers. I'm hoping that someone here has some they would like to get rid of.
Thanks
Greg
Chances are the part numbers you have, have been superseded by a different part number. That was the case with the parts I needed for my MF industrial.
Looks like the 1886553m1 washer is still available from Agco. The other I believe I can get....but could be quite pricey. Get back to me if interested.
Wayne
UPDATE , I was unable to get the 1886555m1 thrust washer, had it ordered but they said they can no longer get it.
OK I just received a response from my supplier. Looks like I can get it. How many do you need?
Can I get you to reply to my E-mail....reply to the "send e-mail" box at lower right, classic view.
Wayne
