MF30 Industrial serial number on chassis?
AaronM
New User
Hi all,
My old MF30 Industrial is missing the serial number plate from under the steering wheel. Does anyone know where the MF30 industrial has the SN stamped on the chassis? I've been looking for 2 days... I'm really hoping someone out there knows the answer to this.
Thanks guys!
I've never seen any MF tractor that had the serial number stamped on any casting, so if the tag is gone you are out of luck. Massey-Harris did stamp the SN just back of the PTO shift lever. The numbers you will find on the transmission and differential case are to help with parts changes over time.
May not help at all, may be irrelevant, but my MF-240-S has serial numbers cast into the tops of the flanges on the rear of the transmission housing. Odd place, but there they are.
