SpottedWonders
New User
I recently bought a one-owner gas 1970 MF40 with loader no backhoe, manual shuttle, live and ground speed PTO and 3Pt with about 2k hours. It belonged to a small construction company. They quit using it when they bought nicer stuff. The problem I have is the hand throttle has something wrong as it does nothing and does not stay in position either. The root of the problem appears to be that what ever keeps the rod from sliding down toward the engine has broken. I can not figure out what keeps the hand throttle rod from the instrument panel from sliding down and through the tension disc (under the battery on the right side) when it is pulled down by the tension from the governor. The spring for the hand throttle (and apparently the bracket) is also missing as I can't figure out where the spring would attach once I get it. Could someone with a similar tractor (I think the auto shuttle is the same from the parts books)send some photos or get in contact with me.
