Hey guys, been kind of a lurker but now I'm in need of some specific help. I have a MF 205 industrial with the 3 cylinder perkins and instareverse transmission. My transmission pan is
leaking pretty substantially and I also have a leak at the pto and left lower 3 point arm. I have bought the necessary gaskets for the the sump cover and front cover and I've bought
the pto shaft seal, but I haven't bought the seal for the lower 3 point arm. I purchased a manual from ebay but had to return it because it was for the wrong tractor, so looking to
order the right one.
Couple questions...
1. Can I drain all the transmission fluid through the plugs in the sump cover and front cover?
2. Is the fluid that is leaking at the pto seperate from transmission?
3. When I drain the fluid and pull the covers, is there anything else I should do or look for with the covers off?
4. What is the fill capacity of the transmission? (I've tried searching and haven't found a straight answer)
5. When I change the pto shaft seal should I go ahead and replace the seal that is leaking at the left lower 3 point arm? If so, what is the process for this?
6. Where is the best place to get a proper manual (preferably one with decent pictures)?
I know this is a lot of questions, but there doesn't appear to be much info about these old mf205's. Thank you in advance for any suggestions.
Couple questions...
