Just purchased a Massey ferguson 3165 that the tph arms do not raise.What kind of oil is used for the hydraulics and is the pump
internal? I'm used to Ford industrials so I need advice on this one. Thanks, jaybird-oh
The pump is internal, there is a strainer for the hydraulic oil that is accessible through the pto lever cover on the left hand side. On the right hand side opposite the pto cover there is another cover that can be removed to see if the internal linkage is working (you will need to drain some of the trans/hydraulic oil out before removing the side covers). Any universal trans/hydraulic oil that meets, or exceeds MF Spec M-1129A will work.
