Parts MH not sure what I have
wilson ind
Bough tractor or parts thereof for the rear end. Have Seven bolt good rime, however I have never seen seven bolt rims. going to
post what I don't need on parts section.
One thing you have is a bad corroded seat spring about to crack in two in fatigue failure, and and dump you right off the back. Id get a new spring if I was you.
brain fart the rims are 32 inch
Tires are no good though one is holding air but still poor condition, Has MH wheel weights and one side dressing sprocket in left wheel Also have fair set of 24 inch rims . good 24 inch tires with eight hole bolt pattern.picture is of 24 inch tires and 8 hole rim
