444 Massey front axle.
centash
Neighbour just restored a 444 standard diesel. It had an aftermarket front axle put on many years ago. He replaced that with a 44 standard axle. Both are wide front non adjustable. I'm fairly certain that the axle from a standard 44 was narrower than that from a 44 special or 444, and that 44s just had the pressed steel rims vs. the cast centre's on a 44 special or 444. Which axle is right for a correct restoration? Ben
The 44 Special and 444/333 standard axles are the same as well as the support. A triple had two different cast front wheel centers. One is the same as the row crop and one has a large "bubble" looking hump in the center. A 44 standard has a 40 inch front axle.
