186081M2 186083m2 steering arm on mf65
Rkh
I found both parts, so may eliminate pto pump to run loader. My question is does these arm make your steering less left & right turn & what parts do i need to attach a pump on front shaft?
The shorter arms don't have to move as far as the longer ones so it should turn sharper (if it isn't hitting the stops on the spindle already), and it will steer faster with the shorter arms.
Can you guys give the part # for the pump & adapter plate for the mf65 gas engine? I looked on agco parts, but couldnt find it.
I checked my 65's steering ams and they are 5 5/8" center to center, so they should be correct for loader use. However, I did have to have the loader hydraulic pump driveshaft replaced (actually had to be newly machined) and the tie rod linkage was still rubbing on the driveshaft. The pedestal components are currently dissasembled. Does anyone have any hints on re-assembly so that there us no interference?
Got the agco page up that ptfarmer gave, says its for 99 loader. Is this for mf65 to?
The link I provided has the parts to mount a MF/Davis 99 loader on a MF 65 tractor along with the front pump, pump mounting, and pump drive. It does not have any different steering components for a FEL. The 50, 65, and other MF tractors the front axle support wasn't designed with a front mount pump in mind. There is usually some interference with the steering, and pump drive. Any pictures of the where you are having issues?
If i can find these parts that is described in agco book page on the 99 loader, wouldn't this work for my mf65?
