Engine parts for Toyosha S148 diesel
I need rods and mains, rings,all seals and head gasket for this engine also clutch if possible.MF AGCO only has rings.Any help would be greatly appreciated.
Thanks Jersey Joe , Southern Global had all the parts I required , however I have found out that the injectors and injection pump also need to be rebuilt and so it just is not worth doing . Iam going to part out the tractor .
(quoted from post at 21:55:23 05/15/13) Thanks Jersey Joe , Southern Global had all the parts I required , however I have found out that the injectors and injection pump also need to be rebuilt and so it just is not worth doing . Iam going to part out the tractor .
Do you still have your Toyosha S148 Engine? I'm looking for a donor engine.
Can anyone direct me to a suppler that carries odds and ends for this 1.1 Litre Massey Ferguson, made in japan around 1986, MF-1020, needing things like belt, hoses, odds and ends, Thank you
