MF150 Hood removal question
bubbanm
Hi Everyone,
I have a MF150 with a Freeman front end loader. My gas tank has rust and is clogging up my fuel strainer. So I need to remove the hood to get the tank off so I can seal it. How do you get the hood off? Can one person do it? Also what is the best way to seal the gas tank?
Thanks!!!
I don't have my 150 here at my home to look at, but I think there are just bolts around the forward grill and dash. Remove the rear lower panels first. Yes, you can lift it.
As to the tank sealer, Por-15 makes a tank sealer but I've not used it.
While the tank is off, it is a good time to re-adjust the valves if needed.
