MF150 questions
16 gallon for mine (I think), gas engine
Measure the surface area of the tank, top/bottom/ends/sides then go to Por-15 web and look around. They may give you an idea how much you need.
I used one can of Red-Kote on my Farmall H, which I think holds 17 gallons or so. Plenty of stuff, and I poured it around and all around and top to bottom and all around the insides, then poured it out back into the can. Let it drain for a while. Had lots left over for tool handles and brackets. DO NOT pour in a second coat, it comes loose inside if you do.
