John Deere D
My Brother-in-law called and mentioned he just purchased a MF 175 with a Perkins diesel. He would like to install a HYDRAULIC PUMP and drive, attached to the front of the Crankshaft. As he is 2+hrs. driving time away,is there anyone on YT that would share a picture of this drive arrangement? I will then have some insight into the parts required.
I noticed on YT parts forum, there is a Mounting Plate with bushings (attaches to crankshaft Pulley), a Drive quill and coupling. I shall be checking to verify if there was ever a factory mounting plate to attach the pump to and or the "SAE" Configuration.
Would any other MF tractors of the same era use the same mounting hard wear?
Bob
Bob
