John Deere D
Tractor Head is compatible to which MF Tractor?
25 + Years ago I was given a BOX with a head in it. Today I spent time on the Internet:
After chasing the casting # 37116990/1 "PERKINS Engine PK 4.236" seems to be the Owner:
The Head is of a DIRECT Fuel Injector design:
Internet INFO as per below:
Perkins PK 4.236 Cylinder Head 37116440 3711604A, 37116990, 3711696A
Are the above heads all compatible with each other or some design difference?
Could someone tell me if this head is compatible with all Perkins PK 4.236 Engines or only Specific Model of the 4.236:
If the head is common to several MF Tractors then I shall retain this head as I could own a 4 cylinder Perkins someday:
The Head appears to be like new:
I know this head will not fit m FE 35 X nor my TEA-20.....
Thanks
Bob..
Thanks
Bob..
