MF165 Canterbury NZ
New User
I have bought a second hand log splitter for my Massey Fergusson 165 and added some hydraulic fittings to the rear of my tractor to use it.
I have a Bare-Co B5210 divertor/isolator valve and used the previously plugged output to be the input for the splitter. I have used the return based on the left hand side below the seat and above the PTO lever.
When the divertor is "right" the front hydraulics run the front end loader control valve next to the steering wheel.
Whe the divertor is "up" the coupled fitting the feed the rear connected log splitter works.
When the divertor is "left" the rear link lift.
Every thing works in isolations althought the splitter isn't as powerful as it was when I tested it on a smaller ford tractor prior to buying.
My problem is that while using the splitter the rear links lift slowly. If you struggle on a piece of wood the lift faster. Once the links are all the way up the pressure to the splitter doesn't increase.
Hopefully a fix to this makes the power of the splitter increase. My theory is that the return I'm using mean the rear links are getting pressure. Have no idea how to fix that thought.
Help!
Help!
