i have all the o- rings and seals in my 2705 three speed shift replaced. when i put air in the three ports one of them the air comes out the centre shaft and i can turn it by hand the other i can turn
by hand and a piston engages and the third port the straight jic fitting engages a piston and i cannot turn the shaft by hand, is this normal? assuming it was normal since the pistons both engaged i
began to put the shift back in the hole and i fought with it for hours but could only get it butted up is there a secret to getting it in or do i just have to fight with it more?
