What tractor is this
Sberry
The tag doesn't list the model,, it says 9A before the serial of 306000. Something fell apart in the clutch assembly, at first I thought it may have been just a pin but the PTO disk is shot, the pressure plate has a crack.
It looks like a 200 series industrial tractor which were yellow. Engines can tell you alot. I'd suggest finding out what engine is in it and then try to narrow it down by looking here:
http://www.tractordata.com/farm-tractors/tractor-brands/massferg/massferg-tractors-industrial.html
It's got a Continental 4 cylinder gas engine so I'd guess its a 20C industrial. If it is a 20C it is a 1979 year model. Some counties will take a agricultural tractor, and paint it yellow so it may not be a industrial tractor (like my 135 was).
That clutch looks alot like the one I just pulled from my MF188 with a Perkins 248 diesel engine. If you are looking for parts they may be the same and I may even have a bit of service info on it.
Thanks for the help, the owner thought it was a TO20 and by the parts and design it looked to be a 200 Ind with the front end lowered. I would say its original paint. I had considered that.
The pressure plate and PTO is busticated. I should order a manual, is it available in IT type?
I will get back to the link, Its got a Cont in it, not sure which model, didn't look yet. The split was simple and tore it apoart before I even shopped any parts.
I was going to call tech from this site and try to order, I suspect it might be wise to wait till Monday morn or so?
Its got Spicer dual clutch and I measured and counted and think I have it narrowed down but wanted to be sure before I pull the pin.
It lasted a long time and I don't trust all the original adjustmen6ts are factory, I only do this on occasion and at one time recalled just exactly how all this worked, I want to set it correctly when its all over.
There are 2 different clutches (different springs is the only difference). Part number 532319M91 is for a turf tractor. The other clutch, part number is 532320M91 (the 12 outer springs are blue).
This is turf, was purchased from a golf course I guess. Looks turf. It has 12 springs. It looked in great general condition and the main disk looked great. I was speculating whether it was original. I will look at spring color.
