correct fluids on work bull ferguson
ohioron
must have done something wrong, never saw this come up, will try again. need to know what fluid is used in the power steering tanr and what is used in the mid tractor fill spot evidently for the 3 point lift system. thanks for the help. excuse me if I duplicated this?
(quoted from post at 03:58:08 09/24/16) must have done something wrong, never saw this come up, will try again. need to know what fluid is used in the power steering tanr and what is used in the mid tractor fill spot evidently for the 3 point lift system. thanks for the help. excuse me if I duplicated this?
The operators manual for the Workbull says Massey Ferguson spec M-1110 for the rear end / transmission. TSC makes a Traveler bran Universal Tractor fluid that says on the back that it conforms to that spec.
For the power steering it says to use type A automatic transmission fluid.
The rear end / mid section and transmission are all one sump.
hope I'm replying to Caryc's answer to my request for the fluid information ,.Not sure I'm answering this right. Caryc, thank you for the information. Just what I needed. I'm on my way to TSC. Ron
