They are fine on hills if the multi power works and is in high.
In fact if its working right it will hold on hills without using
the brakes.
I presume we are talking Diesel? We had a 175 and later a similar tractor (MF 168) with the same engine i.e. Perkins 4/236. They are really good tractors that were fitted with arguably one of the best engines Perkins ever made.
grade drive ways maybe some food plots and garden work. Needing something with weight to hold me on the hills
The 175 is a bit overkill for what you are going to use it for, but if its a diesel, and you are a getting a good deal on it I'd get it. A 150, or a 165 diesel would be ok also.
(quoted from post at 22:37:23 09/22/16) The 175 is a bit overkill for what you are going to use it for, but if its a diesel, and you are a getting a good deal on it I'd get it. A 150, or a 165 diesel would be ok also.
hat's a good deal in one he said the motor has completely been redone and what about a 245
