So I know my pto clutch is bad and will be replacing it soon. Shortly after the clutch went bad I noticed the 3-point started going up slow until after a while it won't lift at all. Can someone tell me, does the pump run off the pto clutch to where it is just slipping so much the pump won't pump? I assume that is the case but not sure. The clutch got soaked in oil and all the pad has came off so I know that problem, just trying to be sure before I take it all apart to replace the clutch, I don't want to put it back together to find out I have to take it apart to repair the pump. Any help would be appreciated. Thanks, Bud
