Put a new clutch kit in the MF 250 and after putting the tractor back together it won't move. Are there some adjustments I need to make? Took the bottom inspection plate off and saw when you depress the pedal it pushes in on the clutch and then when you let off the pedal it lets off on the clutch/pressure plate. Now....the fingers are still against the throwout bearing when you let off the pedal. Do the little finger bolts need adjusting, or the throwout bearing, or the outside pedal linkage? Or what?????
I got the tractor to crawl back about 15 feet but that was it
