Cormiers Cove
I replaced the neutral safety switch as per the correct part number.
How does someone wire this frigging thing. It has 2 small brass terminals that have a small spring type of pin that goes through it and held in place by a tail end.
Is there some sort of special connector I need to crimp on the wires in order to fit into these brass terminals?
And how does someone actually fit these little spring pins back on the terminals?
Also where do these 2 wires go to for a Diesel engine perkins 3 cylinder with a generator?
Thanks
Scott
Thanks
Scott
