Please ID this 35
Ryano
New User
Hi. New to the forum so please most post if it's not in the correct area. I've found a red 35 in a shed. I've taken some photos of the casting numbers and one of the id plate below the key. The old fella who owns it said he thought it had a gold motor ect but got repainted somewhere alone the line. It's a 4 cylinder diesel any help with this one would be great. I'm not a died in the wool tractor collector but I do have a 35x and looking for another project. Cheers. Ryano
ID (under key) sdm 109450
Rhs engine block 302299 ( with "4" under number)
Rhs trans case mhf 182840 m2
Lhs trans case mhf 183253 m5
A bit confusing at that time- the serial number is for a 'Harry Ferguson TO35' of 1959. The engine will be a Standard Motors 23C diesel. Does it run?
Welcome to the forum.
Yep. She runs but I'm really unsure what I've got. It's got an aftermarket front end loader on it.
You are too new. After you post a few more times, YT will trust you to post pictures, and that isn't going to easy at first either.
(quoted from post at 20:21:48 09/11/16) You are too new. After you post a few more times, YT will trust you to post pictures, and that isn't going to easy at first either.
