Pressure relief valve
rockepg
hey guys quick question. I have a 66 MF135 standard 6 speed with live pto unit. What is the part number for the correct pressure relief valve for this unit? Seems like 3 or 4 options but not shure which is correct.
There is 3 different pressure valves, the low 2300 psi valve is replaced with the 3000 psi valve. So there is only 2 different valves 3000, and 2700 psi (the 2700 psi was for orchard tractors).
883402M91 Valve Assembly, Safety (3000 P.S.I.)
884747M91 Valve Assembly, Safety (2700 P.S.I.)
190537M91 1 Valve Assembly, Safety (2300 PSI) (Order 883402M91)
Hmm.. So i am looking at YT's parts list and i don't see a 3000 variety. They list:
http://www.yesterdaystractors.com/Massey-Ferguson-135_Hydraulic-Safety-Valve_883402M1.html
which is part number 883402M1 which i assume is a typo and should be 91. However they list it as 2750 variety. Am i missing something here or does YT just not carry the correct one?
So the threading is the same between them i assume? Both will fit it's just the pressure that is different correct?
