Please help Identify this Tractor
Jaomba
New User
Hello,
I need some help and was hoping some of the experts here could help.
I have a Massey fergusen Tractor which needs some work, it needs a new starter at a minimum, it also appears to be missing something on the left (from the drivers seat) that was inline with the fuel system if you had any idea what that was it would be appreciated. All I know is that This is an old Massey Fergusen Tractor, but I have no idea what it is, it does take Diesel and has mechanical injection.
There is no plate that I can find but there are some number on the left side of the frame casting ;
966137; 966009 it is a 4 speed with low high gear select and a PTO
Also, is this a "Perkins" engine, and can I buy parts for a Perkins?
For some reason the photos did not post, but the phots did post in the "help Identify" section of the main page. Please look there for the photos, and thanks
I added the pic of your tractor as well as a link to your post in the help forum
looks like an MF 35 or 65
35 is a 3 cyl
65 is a 4 cyl
but could be a 50 or 85 as well
there are others that are simalar too
hopefully someone can correctly ID it
as to what is missing on the fuel lines I think it maybe the fuel filter/s
see if you can load a pic of the area were it's missing
the good news is both the starter and fuel filter set up is pretty well the same on most of the
smaller massey's like yours IIRC
YT parts has the fuel assembly and starters for your tractor
Jaombas tractor
the 25 is rare here too I think
I never seen one anywhere here at shows or for sale
but that doesn't mean they aren't out there
lots of 35, 50 & 65's as well as the 100's
I know of 7 35's for sale within 25 miles of me right now
and 1 65
(quoted from post at 14:54:48 08/25/16) the 25 is rare here too I think
and 1 65
Thanks for all the replies, I have looked at other pictures of the 25 and can confirm this is a 25, does anyone know what engine it has and can it cross reference with anything else to figure out how to get a starter for it? Thanks, John
well according to tractor data . com
if it is an 25
Massey Ferguson 25
Massey Ferguson 25 tractor photo
1963 - 1965
Utility tractor
Next model: Massey Ferguson 130
Overview
Engine
Transmission
Dimensions
Photos
Tests
The Massey Ferguson 825 is the designation for the version of the model 25 sold in France.
Production:
Manufacturer: Massey Ferguson
Factory: Beauvais, France
Original price (USD)
$2,545 (1965 )
Massey Ferguson 25 Engine:
Perkins 1.8L 4-cyl diesel (107 ci)
Capacity:
3-Point Hitch:
Rear Type: I
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540
Dimensions & Tires:
Weight: 3,115 lbs [1412 kg]
Front tire: 5.50-16
Rear tire: 12.4-28
25 Serial Numbers:
- Serial numbers unknown -
Massey Ferguson 25 Power:
Engine: 25 hp [18.6 kW]
Drawbar (claimed): 20 hp [14.9 kW]
PTO (claimed): 24.39 hp [18.2 kW]
Drawbar (tested): 20.06 hp [15.0 kW]
PTO (tested): 24.39 hp [18.2 kW]
Mechanical:
Chassis: 4x2 2WD
Steering: manual
Brakes: mechanical shoe
Cab: Open operator station.
Battery:
Volts: 12
if you click the link below it will take you to AGRO parts book
if you scroll down past the sign in area there is a guest log in just click on View Books
then on the search page put in 25 for model and the Massey Ferguson for brand
once that search is there you'll see many options scroll down till you see
25 TRACTOR - 4A-107 ENGINE
you'll be able to look at the different parts of your tractor and how they connect to other
assemblies of your tractor
hope this helps
as all I know of this tractor is what I've read
agro parts
