position control MF135
jjimgee
New User
I recently purchased an MF135 in good shape,however. the position control is seized up.Can anyone tell me why and or how to free it up? thnx :D [/b]
So you can move the draft control lever? If the draft control lever will move chances are the shaft for the position control is stuck in the housing between the lift cover, and the control levers.
(quoted from post at 15:35:28 08/18/16) So you can move the draft control lever? If the draft control lever will move chances are the shaft for the position control is stuck in the housing between the lift cover, and the control levers.
so how do I fix that?
On the underside of the housing between the control levers, and the lift cover the shaft is exposed. Get you some good penetrating oil, and start spraying it up in there. You will probably have to do that for a few days before moving the control levers.
(quoted from post at 13:16:40 08/22/16) On the underside of the housing between the control levers, and the lift cover the shaft is exposed. Get you some good penetrating oil, and start spraying it up in there. You will probably have to do that for a few days before moving the control levers.
thanks PT I'll try that
