Cormiers Cove
Wondering what is the original diameter of the lower link pins MF 35 tractor? The pin on either side of the rear end where the lower 3 point hitch bars attach.
I noticed more then normal wear and play in the lower bars as I'm trying to get this tractor ready for mowing.
I removed the bars and noticed the link pin on either side of the rear end had some sort of bushing over the pins. I was able to take the bushing sleeves off. I measured the diameter of the pins and found them to be 3/4 inch but they did appear to be worn on the back side. The bushings appear to be a makeshift thing from a piece of pipe with 3/4 inch inside diameter and about 15/16 inch outside diameter. It was apparent the sleeves were sanded down on the outside diameter surface that eventually allowed the lower bars to be attached.
Then I checked both ends of the lower bars and noticed that 3 ball ends were 15/16 inside diameter with very much play in the bar socket hole. The fourth end was cut off and a new one welded on with a new 7/8 inch inside diameter ball.
CAT 1 is 7/8 inch. So is this strange size of 3/4 inch for the lower link pins caused by wear and tear and the sleeve bushing was just a quick fix to make up for looseness? And 3 of the 4 lower bar ends are wore out and there is no such thing as 15/16 inch diameter balls?
Or was there some crazy metric sizes back in the day for the lower bars and the lower link pins?
Thanks
Scott
Thanks
Scott
