farmerscotty
OK my good old 65 was rebuilt 475 hours ago, had injectors popped off then were ok, at 350 hours I started having hard having miss. Took injectors out, they needed to be rebuilt were original. Fine did
that all was good. Now I am running a 10ft brushhog on it clipping pasture. We have gone to either (gasp) to start on a 75 degree morning. Slow pickup on rpm's and some smoke.
I have, changed both fuel filters, checked the sediment bowl, have good fuel flow to pump.
It gradually got worse on starting. I knew the starter was weak, rebuilt, good battery too. Turns over great.
I can be running along at pto and next thing I know going up a small hill back to 1200 or slower. No "snap" anymore. Injector pump is my choice for next R&R.
Question......how many different pumps are on 65's.........mine is DPA3243-f610 cav pump.
I don't have 600-900 dollars to rebuild pump. I know where another 65 is setting for parts......not sure if it is indirect or direct injection...
Have looked on here for answer and never found it searching and even on Google...........
SO can someone that reading this help me on the information. THANKS
