MF135 ignition switch.
Old ignition burned up and Just put as universal ignition switch on and when you turn the key to get it to start it turns over but won't start until you click it back one to the on position. Do I have a wrong wire somewhere?
3 possibilities
1. Wired wrong
2. Bad switch
3. Too much resistance in coil input
What are switch markings and how do you have it connected.
According to diagram I have the switch should have Battery input, a wire to activate starter and wire to ignition.
