mf 135/150 lift revisited
IHSMOKE
rebuilt pump new control valve and pistons/blocks .... new draft control spring on rear ... adjusted by I& t manuel several times draft seems to work correctly .....but the position control controls the pump in constant pumping and transport area as soon as ya move lever down it just falls no position control....tractor came to me without any pump pressure worn out ....only would make like 400 psi .... completely rebuilt now its sets off the relief valve and makes over 2800 psi
Hello,
It seems that there is little referencing between the positions of the POSITION CONTROL lever, the vertical lever which operates the pump and the linkage cam housing mounted on the main cross-shaft. These should all be in 'balance' so that when one changes the changes is transmitted to the others. Have you checked that the small tension spring between the POSITION control frame and the 'dog' lever is in place. I suspect that this spring is missing or stretched and may well be the cause of your problem. It should be shown in the I&T manual. If this is in place the frame or dog lever may be worn or bent. It is also possible that the roller which runs on the cross-shaft arm is badly worn. Check for anything worn or bent which might upset the 'balance'. Go back to my original post and familiarise yourself with the operation of the system.
DavidP
The linkage for the draft, and position control is like the inner workings of a clock (only bigger) like a clock every thing has to be close to perfect as possible. I don't know of anyone who didn't struggle the very first time they worked on them, unless they had someone who had experience working on them on hand to help.
