Quick 165 rim question
Found a place that has two good 28 rims 16 inches wide power adjust 4 rails for 225.
Will these work or be too wide for my 16.9 by 28 tires? Decent price?
Thanks. Jason.
I swear. I cannot maintain a thought any more. Crimeny. Talking to myself but 225 each rim. I have not measured the original rim as I am at work figuring this out while I should be working. What is original?
Unless you have to have it all original you could probably find a regular set of rear wheels/centers, and sell the good parts you have of the spinout wheels. Unless you use it for crops like corn, etc there is really no reason to have the power adjust wheels.
The rims are "usually" no less than 2" narrower than the tire width. As far as swapping out the both wheels the about the only way is to find a set from a junked 165, 65. As long as the lug pattern, and the center hole are the same which you could probably find wheels that would fit from other makes of tractors. If the rims you found for $225 is the cost for the pair that would be a steal (as long as they work with your centers).
