I removed carb from tractor and cleaned it because
it was bogging down when a load was on the motor.
Just a little infor for everyone. I had the tank redone
and lined this year and replaced all the fuel lines
and fuel filter. So the fuel system is all new. I put
new plugs, wires and ignition coil. I also replaced
the points and something else I the under the dis
cap. It was running but the Rpm's was dropping
from 2000 to 700. It was acting like it was going to
quit on me. Someone told me to clean the carb out.
This made sense to me since I redone the tank and
fuel lines. Since I removed it and cleaned, by the
way the carb want even that dirty at all inside of it, I
can't even get it to start back up. I checked each
plug and they are getting a blue spark. I removed
the fuel line and it gets a steady stream of gas. I
removed the plug at the bottom of the float and
made sure the float was not stuck and fuel was
coming of the plug hole.
Any help would GREATLY help me out. I am lost as
to why it won't start now.
