Model 232 loss of power steering
Springdrl
Pump appears to be working since it pumps strong fluid stream when the fluid lines at disconnected at the front power cylinders.
The tractor was purchased by a friend and appears to have seen a lot of use.
And suggestions on what the check next? I'm suspecting an issue in the control mechanism and valve on the steering column.
Thanks.
