steven in Tn
am having trouble with the steering on the 275, when first crank it the steering works pretty good, but longer i use it and the hotter it gets the steering goes away. havent had it long but it has leaked fluid at the cylinder since i have had it and im afraid the po has ruined the pump by running it dry considering the pump gets real hot. the cylinder im sure can be rebuilt but not sure if the pump is rebuildable, and im not sure which parts i need since i cant find a serial number nowhere(the plate is gone and dont see one nowhere else all i can find is part numbers on different parts of the tractor). there is a plate on the trans right next to the clutch pedal that says 1867505m4h and 21 a 3 underneath that number, is there anyway to tell by that or any of the part numbers?
