MF 150 governor pin
bubbanm
I noticed on my MF 150 gas engine a long rod coming from the carb just hanging loose. Then I found another shorter rod that looks like the two go together but the pin has come out and is gone. Does anyone know what size pin I need? I assume that is the governor rod.
That should be pretty easy to figure out. Just measure how big the hole is and then how long the pin would need to be to fit. Shoot I have seen a good many where a pin have fallen out and a bolt with a lock nut or 2 nuts where used in place of the pin
