I completely emptied the fuel tank/lines, changed filters, etc. I have fuel all the way to the injectors. If I crack the lines at the injectors it is spitting fuel out all 3. I can't get it to fire though. Do I need to crack some lines somewhere else, like the nut on top of each injector (come to think of it though I did crack the line at the end of the leak off pipe and it had fuel)? Can you flood a diesel like this? Could there still be too much air in the lines even though I have fuel to injectors? Should I crack the injectors and keep turning over for a while to try and bleed the rest of the air out if there is any?
Any tips would be appreciated.
