Pictures aren't the best because it's parked in the garage. Should have pulled it out.
This is probably the 4th 135 I've looked at. Saw it for sale in the local paper for $3,500. Upon looking it over it was evident there were a few issues as you would know if you've read my thread from last evening. This guy bought it off a whim a year ago, parked it in his barn to never use it. Just started it up every few months. It has fresh paint. The red a good job was done but the silver may need done again if I want it to stay pretty. The tin is straight. The tires and wheels are in real good shape. Steering is tight. I think once I get all the issues figured out I will be very pleased with this machine. I did put an alternator on it that I did not mention in my other "issues" thread. I ended up giving him $2,500 for it.
I have also attached a picture of a Davis/MF 102 loader I plan to put on it after I put some paint to it. What you see is not rust but a coat of old red under the yellow. I picked this loader up for $100 and all it needs is the shaft from the front pully to the crankshaft pump, a coat of paint and the bucket needs straightened up a bit.
