testanley
The hydraulic lift works fine with no load but when I attach an implement it will not lift. Pump etc was recently rebuilt. Has
not worked properly since. Any suggestions?
Hi, temporarily replace the top link with a chain attached to the implement and to the lugs where the hinge pin is attached. If this works move the DRAFT lever fully downwards and check for endfloat in the top link attachment point. You may need to remove the control beam to check this.
DavidP, South Wales
