Hi, I have an 1150 don't use a lot so a year or so ago it would not start...figured it was a fuel issue...hoped fuel filters...so I put those on but I can't seem to get fuel primed...most other make tractors almost prime themself with gravity as fuel tanks are higher but on this fuel tanks are down low so gravity not much help. Looks like the lift / primer put in mounted in the middle of the V in the V8 so hard to reach...left filters a little lose and left bleeders on top of filters cracked a little...cranked on with starter several times...nothing?...thinking maybe the lift pump is bad?...looks like I gotta take the hood off to get in to that? I do not consider myself much of a mechanic so looking for thoughts if I am on the right track?
Thanks Reaver
Thanks Reaver
