Going to go look at another MF135, Perkins gas. This one is supposedly a 1970 and has a straight front axle and power steering with cylinders on the front axle. I haven't seen this yet on a 135, straight axle with true power steering. ??? It includes a 6' grader blade and a 7' front plow which I will take off because I have a Davis 102 loader to put on it. The frame was never painted and looks pretty clean. He did paint the red because he said it was faded pretty bad. Per telephone conversation, he tells me everything works including the lights. Tires and wheels are in good shape. Holds fluids well. Gear drive. No smoke or blow by. Tight steering. Hyd aux in back. Tin is straight and not rusted.
Here are my concerns.
1. He says he had the 3pt hydraulics rebuilt by a professional. Did not take the tractor to the guy but took the pump and lifting mechanism, I think. They work well as far as lifting but they are jerky. What causes this?
2. The tractor has almost 6,000 hours. He bought it from a golf course. He had it for 4 years and is selling because he bought a bigger newer tractor and doesn't use this one anymore. What are the common issues you run into with a gas tractor with this many hours? With no smoke or blow by (and I will check fluids well) I would assume the engine should be good now but with that many hours may need an overhaul in the near future.
His bottom line is $3,800.
