Massy T035 clutch release bearing A-2336-1
Howiedoing
New User
Hi all.
I have a massy TO35 split. Before i wreck something how to get the clutch release bearing off the carrier. Its a 9" , 1 1/8 , 10 spline single stage clutch. I assume its pressed on. I dont see any snap rings.
Thank you.
I pull the two side springs off the carrier, then pull the assembly and clamp the flat sides in a vise. Two roll head bars will pry the bearing off, then use the vise to press the bearing back on.
