3650 just stopped?
Srssask
New User
While seeding greenfeed with 1990 MF 3650, tractor just came to sudden stop. No funny noises. No indicator lights. Engine running normal. Hydraulics still function (could raise and lower seeder), trans fluid level right where it should be, pto still works. Tried shifting into all gears and forward / reverse. Shifts fine but absolutely no movement when clutch pedal is released. Any thoughts on what the problem might be?
(quoted from post at 18:29:59 06/20/16) Have you tried to shift it with out pushing in the clutch
Yes. Can shift into any gear with engine running. No clutch required. No grinding. Tractor still sits there.
