PTO clutch change?? Massey 135
paintsmitty
New User
I've read the manual on how to separate the pressure plate to access the PTO clutch. However it is not clear. I watched YouTube videos of other models and they are similar but nor exact. Can anyone let me know how to remove the pins?
Additionally I can't find anything written on how to get the release bearing off. Is it just a matter of detaching the spring mechanism?
Thanks
The lever pivot pins have small groove lock pins that must be driven down part way toward the Bellville spring and removed later after the cover is off. I drive them down just enough to allow the lever pins to come out. Best to replace the lock pins too, I've seen guys re-use them and seen them not stay in place. The release bearing is pressed on the carrier, I remove the two return springs, pull the assembly and clamp the two flat sides in a vise. Use two thin pry bars between the bearing and carrier to pry it off. Use the vise to press the bearing back on.
Dieseltech
Thanks so much. That makes perfect sense. I cant wait to get home to start. I just didnt want to break anything
Im a car painter by trade. If you know anyone who may need advice on refinishing their tractor have them hit me up.
Thanks again
Paintsmitty
