mf- 30b wont start after running out of fuel
tomrl
New User
mf-30b ind. wont start after running out of fuel. I am having trouble bleeding the air off. It appears to have fuel to the injector pump but it still wont start. The manual says to loosen the fuel lines at the injectors and run the motor with the starter- I do not know where those connections are- Any suggestions would be appreciated - thank you
As you have the manual I'll assume you have bleed the 2 bleed bolts on the injector pump as you say
you have fuel there
If you follow the fuel lines coming out of the pump you'll find at the other end of them the
connection to the injectors
IIRC you need to lift the fuel tank to get proper access to them
proper bleeding starts at the lift pump bleeding all fuel filters in line in order of how fuel
reaches tem using the lift pump hand primer not the starter after that then theres the two bleed
crews on the injector pump check your manual for which one 1st still using the hand primer on the
lift pump
Last is the injectors to be bleed
good luck even if you do everything right the 1st time you may have t go back and start from the
beginning as it's hard to get the air locks out of the system mostly at the fuel filters
Thank you for the info- I did everything you said except for the injector connection- Thought I would give it one more try before I had to lift the fuel tank. Must have lot real lucky because after about 20 seconds of cranking she fired up
